Коды
Вот, что нашёл-
111 P01301 Oxygen (O2)sensor
P0335
P1390
P1391
p1398
-No Crankshaft Reference Signal At PCM
-Timing Belt Skipped One Tooth Or More
-Intermittent Loss Of CMP Or CKP
-Misfire Adaptive Numerator At Limit
12 Air flow sensor
13 P01101 Intake temperature sensors
13 P1297 No Change in MAP from Start to Run
14 P01201 Throttle position sensor TPS
14 P0107, P0108, P1296 MAP Sensor Voltage
14 P1496 5 Volt Supply Output Low
15 Idle speed control motor position sensor
15 P0500 No VSS Signal
16 Power supply voltage
16 P0325 Knock Sensor No. 1 Circuit
17 P0125 Closed Loop Temperature Not Reached
18 Cranking signal (Ignition Switch - ST)
21 P01211 Engine coolant temperature sensor
21 P0131, 0133, 0133, 0134, 0135,0137, 0138,0140,0141 Problem with Upstream and Downsteram HO2S
22 P03351 Crankshaft position sensor
22 P0117, 0118 ECT Sensor Voltage)
23 Camshaft position sensor
23 P0112, 0113, IAT Sensor Voltage
24 P05001 Vehicle speed sensor
241 P0121, 0122, 0123,1295 TPS Voltage
25 P01051 Barometric pressure sensor
25 P1294 Target Idle Not Reached
26 P05101 Closed throttle position switch
27 P05511 Power steering pressure switch
27 P0201,0202,0203,0204 Injector No. N Control Circuit
28 A/C switch
29 Park/Netral position switch
31 Knock sensor
31 P0441,0442,0443,0455,1486 Problem with EVAP System
31 P1494, P1495
-LDP Switch/Mechanical Fault
-LDP Solenoid Electrical Malfunction
32 P0401, P0403
-EGR System Failure
-EGR Solenoid Circuit
32 Manifold absolute pressure sensor
34 P01001 Volume air flow sensor reset signal
35 P1487,1489,1490 Problem with Radiator Fan Control Relay Circuit
36 Ignition timing adjustment signal (is not memorised)
37 Volumetric effeciency
37 P1899 Park/Neutral Switch (Transaxle Range Switch) Failure (A/T)
38 Crankshaft position sensor (reading possible below 2000 rpm)
39 P01501 Left bank heated oxygen sensor (Front)
41 Injectors failure
42 Fuel pump
43 EGR-System: Valve, Solenoid, Vac, or Temp. Sensor
43 P0300,0301,0302,0303,0304, P0351
-Cylinder No. N Misfire
-Ignition Coil No. N Primary Circuit.
44 Ignition coil, ignition power transistor unit failure
44 P1492,1493 Battery Temperature Sensor (!) Voltage High or Low
44*
45 Idle air control position
45 P0700 EATX Controller DTC Present
47 Injectors
49 A/C compressor clutch relay
51 P0171 Fuel System Lean
52 P0172 Fuel System Rich
52 Ignition coil, ignition power transistor unit
53 P0600, P0601
-PCM Failure -SPI Communications
-Internal Controller Failure
53 P0600, P0601
53 Ignition coil, ignition power transistor unit
54 P0340 No Cam Signal At PCM
54*
55 IAC Valve position sensor (Servo Valve Position Sensor)
56*
ml
58
59 P01361 Heated Oxygen (O2) sensor (rear)
61 Transaxle torque reduction signal
61 P0106 Barometric Pressure Out Of Range
61*
62 Induction control valve position sensor
62 P1697 PCM Failure -SRI Mile Not Stored
63 P1696 PCM Failure -EEPROM Write Denied
64 P0422 Catalytic Converter Efficiency Failure
64*
65 P0551 Power Steering Pressure Switch Failure
66*
69 P01561 Oxygen (O2)sensor
71 Vacuum control solenoid valve (TRC)
72 Ventilation control solenoid valve (TRC)
73 Fuel tank pressure differential sensors
77*
78*
79*
81 P01701 Long-term fuel compensation
82 Short-term fuel compensation
83 Long-term fuel compensation (Calif.)
84 Short-term fuel compensation (Calif.)
87 Calculation load
88 P01251 Fuel control condition
89* Fuel control condition (abnormal fuel system)
91*
92*
94*
95*
95 P14001 Manifold differential pressure sensor
99*
152 P0703 Stoplight Switch Circuit
Short pulse
Normal state
Note: Not all trouble codes are used on all models
for example, (1) - is actual for 1999 Diamante, etc.
* As for GDI-Engines (Courtesy Thomas Essemann).
** MMC have also and others definition for MIL-DTC (green - for a 1999 Vehicle)
*** MMC have correct procedure for read DTC (without Scan Tool) for OBDII-equiped vehicle
when using the voltmeter or by the indicator's deflection (MIL or "Check Engine") for ABS,
Heating & Air Conditioning, A/T, TRC, ECS, Cruise Control, Air Bag system's.
**** SAE (J2012) or Manufacturer's codes.
Последний раз редактировалось Shum; 15.01.2011 в 17:42..
